1993 Mazda RX7 AC problem
1993 MAZDA RX7
JESSE-RX7
Air Conditioning problem
1993 Mazda RX7 Two Wheel Drive Manual 121000 miles
Hey, my RX7 Fd has a problem with it's AC. I run the AC to dry up the fog inside my windows, and all of a sudden as im driving down the road it shuts off, and my windows fog up instantly. When it shuts off it doesn't seem to turn back on for quite a while, if at all. If it does turn back on, it does not seem to absorb the moisture on the window as well as it should, or as well as it used to.
My rx7 is actually a '92 imported from japan, they were not made in N.A. until 93, but identical car.
The car still has it's origional r12 to my knowledge.
Any suggestions?
thanks, guys.
Jesse
Mar 15, 2010 at 1:43 AM
Check the high and low pressures could be a freon problem, mag clutch, compressor and pressue switch, get an AC Tech to look at it-
Mar 15, 2010 at 2:00 AM
