1991 Mazda RX7 Flooding
TRIPOD67
  • 10 POSTS
I have a 1991 Mazda RX 7. It was running rich for a while, then it wouldnt start. It is putting so much fuel in the engine that it constantly gets the plugs wet. Its getting good spark to the leading and trailing plugs, and the plugs are new. The injectors are spraying way to much fuel. any ideas.?
Jan 4, 2006 at 9:12 AM
2CARPRO JACK
  • 11,533 POSTS
coolant sensor
Jan 24, 2006 at 9:46 AM
COSMO
  • 347 POSTS
Have the compression checked by a shop that knows how to do a compression test on a rotary engine. Rx-7's all smell like they are running to 'rich'. Its just the way they are, rx-7's use alot of fuel and have very agressive fuel trims while running. If it is flooding the engine alot, you may have a weak chamber, apex seal(s) or side rotor seal(s). By no means take your rx-7 to the local shop and expect 'expert' diagnosis of a rotary engine. Take it too a 'rotary' specialised shop or a Mazda dealer.
Cosmo..Mazda Tech
Jan 24, 2006 at 3:27 PM
Suggested Repair
Check the coolant sensor. Have a rotary-specialist shop or Mazda dealer perform a proper rotary compression test, since flooding may indicate a weak chamber, worn apex seals, or side rotor seals.
Conversation Summary
The owner of a 1991 Mazda RX-7 reported a rich-running condition that progressed to a no-start, with wet plugs and injectors delivering excessive fuel despite good spark and new plugs. One expert suggested the coolant sensor. Another noted that RX-7s normally use a lot of fuel and can smell rich, but recommended a rotary compression test at a specialist shop or Mazda dealer to check for a weak chamber, apex seals, or side rotor seals.
