1991 Mazda RX7 engine won't start
1991 MAZDA RX7
NAVALES LEO
Electrical problem
1991 Mazda RX7 Two Wheel Drive Manual 100000 miles
please help me how to fix my car, sounds like it going to start but it won't go up, where is the fuel fill located at?
Aug 26, 2010 at 9:00 AM
Do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it and keep testing
Aug 26, 2010 at 9:02 AM
