1991 Mazda RX7 engine doesn't start
1991 MAZDA RX7
NAVALES LEO
Engine Performance problem
1991 Mazda RX7 Two Wheel Drive Manual 100000 miles
please give me idea to fix my car, i don't know what's wrong with it, it sounds starting but it go.
Aug 26, 2010 at 7:34 AM
Pick your symptom:
**Cranks but no start condition:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
**No crank at all/nothing/nada when key is engage to starting position
Could be a blown fusible link, the starter, starter relay, clutch switch/park and neutral switch and ignition switch assuming the battery and connections are good. Note:If it doesn't apply disregard.
Aug 26, 2010 at 5:00 PM
