1990 Mazda RX7 wont stay running
1990 MAZDA RX7
PUPUPUPUTTER
Engine Performance problem
1990 Mazda RX7 Two Wheel Drive Manual 150000 miles
i have a 1990 rx7 convertible it will start up but wont stay running i have so far found that it doesnt feel like their is any vacuum going to the choke but have checked all hoses no leaks their is what looks like a throttle controlled vacuum cylinder and it feels like the line is froze but the car will stay running if i hold starter on can you help or tell me what i can narrow ir down to or tell me where i can get a vacuum hoses routing guide so i can make sure they are all ran right anything would be helpful thanks
Jun 30, 2008 at 12:48 PM
Check the bypass air control valve and the throttle position sensor and also check fuel pressure
Jun 30, 2008 at 12:59 PM
KHLOW2008
  • 41,814 POSTS
Check the ignition switch.
Jul 1, 2008 at 4:59 AM
