1990 Mazda RX7 Idle speed
ALRIECK
Engine Performance problem
1990 Mazda RX7 Two Wheel Drive Automatic 125000 miles
Engine will not idle with the air conditioning on. Seems to idle to low, sometimes kills when I brake to a stop.
Manual cautions not to increase idle because it will chainge the shift points causing transmission problems.
Jul 18, 2010 at 12:40 PM
  • 75,988 POSTS
Check if it has an idle up solenoid if it does test it-its job is to increase the idle speed when the clutch engages the compressor due to the added load on the engine
Jul 18, 2010 at 10:48 PM
