1989 Mazda RX7 starting
AJDAILEY
Engine Mechanical problem
1989 Mazda RX7 Two Wheel Drive Manual
hi i have an 89 rx7 NA... it ran great for 4 months then the fuel pump went out so i replaced it and it only cranked once after that. then it sat for about 4 months i just checked all the spark plugs and they all fire bit there is no fuel getting to the fuel rail at all.... so i have spark and it wont start...is it possible that the fuel pump went out again?
Sep 10, 2010 at 7:41 AM
  • 75,988 POSTS
Could be the fuel pump or the injectors are not pulsing, clogged fuel filter/fuel strainer pick-up sock in the tank
Sep 10, 2010 at 9:04 AM
