1989 Mazda RX7 Electric Fan problem
1989 MAZDA RX7
JUNT86
  • 6 POSTS
Electrical problem
1989 Mazda RX7 70k miles
Hi
Am having a bit of a problem regarding my electric fan.
Sometimes the fan stops to work recently for some unknown reason, thus my water temp goes up.
The fan usually kicks in automatically around 89 degrees.
When the fan stops working i had to pull over, switch the engine off, pop the hood up & play about with the fuse, eventually it'll come back on.
I notice when am trying to get the fan back on via playing about with the fuse, i can hear the relay clicking.
I have changed the fuse & relay thinking it should solve the problem but no. It still occurs.
Any ideas?
Regards Alex
May 19, 2010 at 6:12 AM
Hi JunT86, Welcome to 2carpros and TY for the donation Inspect and test the water temperature switch on top front of engine and ground point G107 behind right headlight
https://images.2carpros.com/forum/automotive_pictures/12900_f1_18.jpg
https://images.2carpros.com/forum/automotive_pictures/12900_f2_18.jpg
https://images.2carpros.com/forum/automotive_pictures/12900_f3_9.jpg
May 19, 2010 at 7:46 AM
JUNT86
  • 6 POSTS
I can really see the description on the images, kinda small. Can you post a bigger version?
Oh forgot to note that its been modified & and fitted with Defi gauge Water Temp and checked the sensors are fine.
May 19, 2010 at 8:33 AM
Give me your email addy and I'll send it-that's as far as I can buff it up
May 19, 2010 at 9:19 AM
JUNT86
  • 6 POSTS
junt_racing@hotmail.com
Thanks
May 19, 2010 at 9:40 AM
Its on its way-
May 19, 2010 at 9:51 AM
