Electrical problem
1988 Mazda RX7 Two Wheel Drive Manual 186000 miles
I have a 1988 Mazda RX-7 GXL non-turbo. I replaced the fuel pump started it and it ran great. Then I let the vehicle set unused for a few months. When I went to start it I continously tried starting it but I was unsucessful. Finally I took the fuel pump out and realized it was clogged. I unclogged it and know I am getting fuel from my fuel tank through the filter and to the engine with no problem. But I still could not get it to start. I took to a shop and the tested the fuel injectors and said they were not gettin any power. I was advised to replace the ECU computer and i did but this did not fix the problem. Now I am being advised to replace the crank angle sensor but before I spend $400.00 I want to be sure that there is at least a good possiblity that will fix my problem, and give power to my injectors. Thanks for your help.
Feb 20, 2008 at 1:51 PM
