No spark from coils?
1988 MAZDA RX7
113,000 MILES • 4 CYL • 2WD • MANUAL
JOHNNY HANDSOME
I have checked all as said in haynes book,Crank sensor ,coils,main relay all gave good readings.went to ecu opened it and saw a burnt ressistor or something blue ,I replaed with an other ecu that is not from a convertible and I still get no spark please help.
Apr 27, 2009 at 3:50 PM
RACEFAN966
  • 5,029 POSTS
OK if you don't mind here is the specs on the crank sensor. Between term G1 and G2 ohms should be 110-210 ohm. Between term Ne1 andNe2 should be 110-210 ohms as well. Here is pic for the term locations.
https://images.2carpros.com/forum/automotive_pictures/249564_Graphic_77.jpg
You need a tester to check the ignitor here is what they are refuring to. Do you have access to this tester?
https://images.2carpros.com/forum/automotive_pictures/249564_Graphic_78.jpg
Apr 28, 2009 at 3:35 AM
JOHNNY HANDSOME
Thanks for the quick reply, I have done the coil check with ohm tester and it gave a good reading the ignitor check is going to be impossible for me, I have no access to the tool.I did xchange both coils with another working pair and still no spark.Is the ecu different in a conv .I did change my N338 with a N3y6 would this be the problem? Crank gave good readings,main relay and coils.Could it be theft detterent ecu or similar problem.
Apr 28, 2009 at 4:07 AM
RACEFAN966
  • 5,029 POSTS
The ignitor controls the coil to give it power so it will fire. Do you have acces to a known good ignitor? I will look for another way to test the ignitor in the mean time get back to me about a known good ignitor and then I will look for the module test too. This may help all you need is a volt meter. On the ignitor disconnect the 2 prong connector at the ignitor and hook the meter up in series with the black wire with yellow stripe terminals turn the ignition on and you should get 12 volts. Let me know what you find.
Apr 29, 2009 at 3:20 AM
