1988 Mazda RX7 1988 mazda rx7 turns over/wont start
1988 MAZDA RX7
TROUBLE8ME
Engine Mechanical problem
1988 Mazda RX7 Two Wheel Drive Manual
This car has been quite the project. It was recently bought in October of '08 , used for about a month, then it died. It was completely repaired , went about 5 miles down the road and caught on fire. (Nice huh)
Finally , it is about to be reborn again. Everything damaged by fire has been replaced. We tried to start it yesterday but she wouldn't turn over. It is not creating any spark. Any ideas would be greatly appreciated.
Apr 25, 2009 at 10:25 AM
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,distributor pick-up coil, ignition control module, ignitor crank angle sensor cam and crank sensors- Note: If it doesn't apply disregard it
Apr 25, 2009 at 10:51 AM
TROUBLE8ME
Thanks for the quick reply. I will update shortly as to the result.
Apr 25, 2009 at 11:28 AM
TROUBLE8ME
We managed to get the car to start but it wont idle on its own. White smoke comes out of the exhaust. It looks nearly hopeless. =)
Apr 26, 2009 at 10:28 AM
Try adjusting the idle speed screw to raise the RPM unable to-could be the headgasket blown or an intake manifold leak allowing coolant to enter the cylinders-that's the reason for the white smoke
Apr 26, 2009 at 11:10 AM
