1987 Mazda RX7 reverse light and signal light right front s
1987 MAZDA RX7
200,000 MILES • 4 CYL • 2WD • MANUAL
WASALAKCAG
hi i have problem with my 87 mazda rx7. i can not pass the lamp inspection because the reverse light is not working and the signal light from the front right side is not working, it will light but if u change signal its not blinking. the light just turn on.
Jan 21, 2009 at 8:21 PM
MIKE H R
  • 3,094 POSTS
With reference to the back up light not working check the fuse for the back up lights. with the signal light just staying on . I would chech the other light on that side to see if it lights. If both light check the flasher.
Jan 22, 2009 at 12:56 AM
