1987 Mazda RX7 break pressure
KMATA
Brakes problem
1987 Mazda RX7 4 cyl Two Wheel Drive Manual
i have a 87 mazda rx7 gxl and when i push the breaks the car doesnt start to slow down until the pedal is all the way down. i had it inspected and turns out im getting more pressure n the rear than in the front. my questions are: is the lack of pressure the reason why i have to press the pedal all the way down inorder to slow sown or stop, and what do i do to fix this?
Feb 10, 2009 at 8:27 AM
  • 75,988 POSTS
If calipers/lines/wheel cylinders are not leaking-I recommend you check the brake master cylinder for an internal leak.
Feb 10, 2009 at 8:38 AM
KMATA
thanks man i will do
Feb 10, 2009 at 10:08 AM
