1986 Mazda RX7 Hydrolic clutch
98,645 MILES • 4 CYL • 2WD • MANUAL
JRC52DE
Do i have to have a pro change out ny Hydrolic clutch or can i do it myself and what tools would it take
Aug 8, 2010 at 6:00 AM
  • 31,937 POSTS
Hi there,
This is not normally a job i would recommend a novice home mechanic to attempt, you really need the car up on a hoist and use a transmission jack and an engine support to aid in the removal, also removing the drive shafts are often very difficult, get a mechanic to do this,you also need to get the flywheel re machined and be able to re fill the transmission with oil.
mark (mhpautos)
Aug 8, 2010 at 11:33 PM
