1985 Mazda RX7 car sat 1 month and wont start
PHILODUM
Electrical problem
1985 Mazda RX7 Two Wheel Drive Manual 200000 miles
Car sat 1 month and will not start. only the front coil is sparking , is this right?
Feb 28, 2009 at 7:02 AM
RICH CRITES
  • 75 POSTS
With that many miles on your engine, it maybe the apaex seal may be worned out. Sometimes if you pull all four spark plugs out, pour oil down carbu. and crank the engine over, you can get the apex seals to seal , replace spark plugs and wires. Spray some quick start down the carbu with it completely open and crank the engine over. Worst thing you can do for rotor engines is to let them set. *When the engine starts it will smoke like crazy for a short while, it is normal.
Apr 1, 2009 at 6:56 AM
