1983 Mazda RX7 timming
HAGENMITCH
Engine Mechanical problem
1983 Mazda RX7 Two Wheel Drive Manual 199000 miles
my engine runs rough at idle. the timming marks are at 2 oclock when engine is running. ingniters tested ok, i have new coils, cap, and spark plugs. why is my timming retarded? this is the only way the engine runs.
mitch
Jul 24, 2010 at 7:49 AM
TAK
  • 14 POSTS
[quote:1a0c065d88="hagenmitch"]Engine Mechanical problem
mitch[/quote:1a0c065d88]
did you check the engine compression? if its not you need check compression. but make sure use special compression tester for rotary engine.
regular compression tester cant check all 3 cylinder.
Aug 3, 2010 at 12:00 PM
