1980 Mazda RX7 Cuts Out at Moderate Speed
Cosmo...Mazda Tech
Suggested Repair
There is no separate low-speed coil on this RX-7; it uses a dual-coil, twin-points system for the leading and trailing plugs. Confirm the plug wires are on the correct plugs (L/leading lower, T/trailing top; L1/T1 front and L2/T2 rear). If the car was stored, check for clogged primary carburetor jets, and have a rotary-trained Mazda technician diagnose the cutting out.
Conversation Summary
The owner of a 1980 Mazda RX-7 with 73,000 miles reported the engine cutting in and out at moderate speeds but running fine around 4500 rpm. Fuel filter, plugs, rotor, cap, wires, and carb cleaner did not help. One reply suggested a low-speed coil. A Mazda technician said there is no low-speed coil, explained the dual-coil leading and trailing plug system, advised verifying plug-wire routing, mentioned possible clogged primary jets if the car sat unused, and recommended a rotary specialist.
