wipers do not work
MAZDA PROTEGE
RLMATZ
I have a 1998 and just recently the windshield wipers stopped working. When they are turned on, I can hear the motor working, but nothing happens. Any help would be great. Thanks!
Mar 2, 2007 at 10:01 AM
MIKE H R
  • 3,094 POSTS
first check to make sure the wipers are secured on. see if you can see the wiper motor. does the wiper arm try to move?
Mar 2, 2007 at 11:52 AM
COSMO
  • 347 POSTS
More than likely the wiper link form the motor to the passenger wiper pivot is broken. Your local Mazda dealer should have it. The new link comes with the passenger wiper pivot, it might also be in your best interest to change the link to the driver pivot too.
Cosmo...Mazda Tech
Mar 5, 2007 at 10:09 PM
DBRUNO7613
The windshield wipers quit working on my car. Not even a tap or pull on them will get them working. Could this be a wiper motor issue? Also, a good year ago the radio display seems to be getting worse when it comes to displaying the numbers. It seems that it only shows part of the numbers and I can see them clear when I tap on the display. Could these issues be related?
Jan 5, 2017 at 10:52 AM (Merged)
2CARPRO JACK
  • 11,533 POSTS
i doubt if they are related. check the fuses and connections at the wiper motor.
KLGMPC
Four cylinder front wheel drive automatic 88,136 miles
I can hear the windshield wiper motor running. It even turns on and off when set on intermittent. But the wipers do not move. Can I fix this problem if I replace the entire wiper motor assembly?
KHLOW2008
  • 41,814 POSTS
Hi klgmpc,
No, you do not need to replace the wiper motor assembly.
You need to replace the wiper links.
TIANOT
hi! i have a 2000 model, 118,000 mileage. my windshield wiper is not working, but i heard some noise when i turn it on my windshield wiper. the windshield washer is working. i do not know what is wrong. how can i fix the windshield wiper? can you help me for this? thanks,
LOSONE
  • 1,616 POSTS
Either the windshield wiper arm is disconnected or you need a new windshield wiper motor.
DAVID7
Front wheel drive automatic 150,000 miles
driver side wiper works fine, passenger side does not work at all. How do I correct?
AARONBUETTNER
Four cylinder two wheel drive automatic 133,000 miles
My windshield wipers do not work. I replaced the windshield wiper motor with a new one. It still did not work. I looked at the fuse and it was not blown. Why is it not working? Do you have any suggestions?
By the way this is on a LX 1.8 DOHC, front wheel drive
