Temperature goes up and down
MAZDA PROTEGE
BONEBONE
My car is a 1996 Mazda Protege 1.5L, automatic, and it's about 132,000 for the mileage. Recently it has been replaced with a new distributor + cap, fuel filter, sparking wire and timing belt. I also took it to have oil change and transmission fuel change. But then now when I hit the brake and stop the car for a longer time (maybe 1-2 mins waiting for traffic), the cursor in the H/L gauge on the odometer would point up into the high temp region. While I keep running after I stopped, the cursor would point back down to the normal temp region. I never had this problem before the car had oil change and transmission fuel change. I called the auto repair shop and they said that it's nothing related to those parts. Therefore, I don't know what happens to it and I wanna know if it's a serious problem to the car...Thank you very much.
P.S. I am running the car with the air-conditioning on.
Aug 22, 2007 at 8:55 AM
[quote:7dc59018b3="bonebone"]My car is a 1996 Mazda Protege 1.5L, automatic, and it's about 132,000 for the mileage. Recently it has been replaced with a new distributor + cap, fuel filter, sparking wire and timing belt. I also took it to have oil change and transmission fuel change. But then now when I hit the brake and stop the car for a longer time (maybe 1-2 mins waiting for traffic), the cursor in the H/L gauge on the odometer would point up into the high temp region. While I keep running after I stopped, the cursor would point back down to the normal temp region. I never had this problem before the car had oil change and transmission fuel change. I called the auto repair shop and they said that it's nothing related to those parts. Therefore, I don't know what happens to it and I wanna know if it's a serious problem to the car...Thank you very much.
P.S. I am running the car with the air-conditioning on.[/quote:7dc59018b3]
Last time you changed the thermostat?
Open hood -start the car-let it warm up for 20mins. is the radiator fan coming On-if so now turn Ac on-do you see both fan turning.
Aug 22, 2007 at 9:37 AM
BONEBONE
I might have looked at a wrong place, I looked at the big fan at the very front of the car which is just right behind those front lights. When I had started up the car, the fan did not turn on..., so it's the fan not working then..? How much approximately would cost to replace one? I did not change the thermostat.
Aug 22, 2007 at 12:37 PM
