Starter problem
LEDNEY
2002 Protege 104000km - Car cranks but often will not start, was told it was fuel pump. I have had it replace twice now and mechanics still don't know what the prob is. Strange thing is that is seems to start better in cold weather???
Sep 20, 2007 at 9:59 AM
  • 75,988 POSTS
Duplicate the problem-when it refuses to start one of this is missing Spark and Fuel. Have the mechanic look into it.
Sep 20, 2007 at 10:39 AM
LEDNEY
What I have had done so far is an emissions service, fuel pump replaced and fuel pressure regulator replaced and none has helped...
Sep 21, 2007 at 4:18 AM
  • 75,988 POSTS
[quote:da1fc2bb20="ledney"]What I have had done so far is an emissions service, fuel pump replaced and fuel pressure regulator replaced and none has helped...[/quote:da1fc2bb20]
Could be that its not getting an ignition spark-Have him check the ignition components.
Sep 21, 2007 at 6:50 AM
DATSUNRAISED
  • 37 POSTS
That sounds like a coil going out. When it's cold, the windings will be a little closer together, but after it warms up, they can spread farther apart. Does the car run roughly after it gets hot?
Nov 27, 2007 at 1:07 AM
