Screaming Mazda
A.LEGER
Hello there! I don't know if it has anything to do with the fact that the weather is getting colder up her but I hear a shreaking loud noise right after I turn the engine on. The noise goes away and reappears later, the only thing that makes it go away is if I press the gas pedal, then it screams again and fades off. I drive a 1999 Mazda Protegé LX. It's all original (70 000 miles) except for new brakes & muffler. What's wrong? Thanks a million!
Oct 30, 2007 at 6:33 AM
KATJA73
kind of depends on you. i've replaced the one on my 99 explorer. it rusted out and i lost most of the antifreeze. had it done at local repair shop for $220; includes labor for getting into engine. if you don't replace it you may end up needing a new engine.
Aug 27, 2007 at 4:59 AM
MERLIN2021
  • 17,250 POSTS
It is most likly the serpentine belt, and the tensioner pulley need to be replaced! Thats the belt that drives all you goodies under the hood! Formerly know as a fan belt!
Oct 30, 2007 at 9:11 AM
KELLIAK76
I am having the same problem on my 2003 Mazda Protege after having the two belts replaced. Why only after having those replaced does that start?
:( It turned out to be that the belts were to loose, go figure.
Nov 8, 2007 at 12:48 PM
