Rough idle
KLOOG
  • MAZDA PROTEGE
1991 mazda protege 1.8 DOHC
I have a constant rough idle that I can't fix. I've checked all the obvious things
1. Motor mounts (2 replaced, 2 others checked and seemed fine)
2. Wires/plugs/cap/rotor replaced
3. Throttle body gasket replaced, throttlebody cleaned
4. Changed exhaust manifold gasket checked for leaks
5. Changed o2 sensor
6. The IAC was broken but I replaced it (didn't help)
I am really at a loss about what to do to fix it
the idle is steady and rpms appears to be proper for the car
it's just really bad vibration, it occurs during hot and cold operation
if anyone has any suggestions i'd love to hear them
Thursday, April 19th, 2007 AT 11:55 PM
Find the EGR and open it up and clean it out.
Friday, April 20th, 2007 AT 12:06 AM
KLOOG
This engine doesn't have an EGR valve
Friday, April 20th, 2007 AT 8:45 PM
I don't get this one, the idle is steady and rpms appears to be proper for the car
it's just really bad vibration. Sounds more like a mechanical problem.
Ignition timing okay -no vacuum leaks?
Bad vibration when your moving from a stop or while idling at stationary.
Friday, April 20th, 2007 AT 9:39 PM
KLOOG
The rough idle is when the car isn't moving, I haven't checked timing and there are no vacuum leaks
Friday, April 20th, 2007 AT 9:43 PM
BTW is it a Carb or and EFI
How about tranny mounts they ok too. Be advised the EGR is been around since 1973, are you positively sure?
Could be the brake booster/check vale/hose, PCV valve to include its hose, intake manifold gasket, throttle body shaft
there are no vacuum leaks: Did you use one of these methods to confirm that theres no leak-Carb cleaner, propane, pressure, smoke, electronic vacuum leak detector, Vacuum gauge, exhaust analyzer w/propane.
Saturday, April 21st, 2007 AT 12:00 AM
KLOOG
I might be wrong about EGR, I am going to try to find and clean it, also check compression
Saturday, April 21st, 2007 AT 1:07 AM
