You might have to use an impact wrench with a Phillips bit to get those large screws out, the constant heating and cooling of the drums almost 'seals' them in. Be careful with a hand screwdriver or cordless drill/driver, you can strip them real easily.
After that, just hit the drum with a small sledgehammer firmly on each side a couple of times and drum should come off. I have found using the holes in the drum opposite the large screws don't work great as the force needed to get the drum off countering it with screwing something into it tends to strip the threads in those holes.
Feb 28, 2008 at 10:43 AM
