2003 Mazda Protege Poor Acceleration; Almost Stalls
2003 MAZDA PROTEGE
109,000 MILES • 4 CYL • FWD • AUTOMATIC
ATLANTA MAZDA GUY
I am original owner of:
2003 Mazda Protoge
109,000 Miles
Have always run 87 octane fuel - until recently (see below)
Oil changed per owner's manual; at 85,000 miles started using Mobil One High Mileage.
At 95,000 miles (summer of 2007) had the 100,000 major service done - at that time serious rattle coming from engine. Had timing belt adjusted; replaced water pump; had valves adjusted.
Current Problems:
1. Check engine light comes on some days steady, other times it doesn't come on at all. Had code read by Autozone.
2. Loud rattle has returned - volume of rattle increases as I give car gas.
3. RPM's drop very low then pick back up when car stopped. Feels like vehicle may stall.
4. When accelerating from a stop, e.g. traffic light, the vehicle has a very noticeable hesitation.
For the past month I have run 93 octane fuel in car. I have also put in STP Fuel Treatment two of the times I filled the gas tank. Seems to make engine run smoother, rattle is much less or almost gone...But the problems have come back.
Should I get my fuel injectors cleaned? Valves adjusted again?
I would like to keep this car for at least 5 more years, but don't want to break the bank.
Apr 24, 2008 at 12:49 PM
SOULNET
I have a 2003 protege lx 2.0 liter that had an idle problem with the engine light coming on a couple years ago. Took it into the dealership and they replaced a part free of charge due to a recall or something. Haven't had a problem since then. Believe it was a MAF sensor gone bad.
Apr 25, 2008 at 1:44 PM
