2003 Mazda Protege Low beams not working.
10,200 MILES • 4 CYL • 2WD • AUTOMATIC
CHRISTOPHERBYMAN
Hello, My low beams went a bit dim for a few weeks and then finally went out. My high beams and fog lights still work fine. I checked the high and low beam fuses under the hood with a multimeter and they were both fine. What do you think could be causing this? Thank you! Chris
Aug 11, 2010 at 2:58 PM
BLUELIGHTNIN6
  • 16,542 POSTS
check the head lamp relay. may not be likely but also check the bulbs themselves.
Aug 11, 2010 at 3:29 PM
