2003 Mazda Protege Lifter noise?
135,000 MILES • 4 CYL • FWD • MANUAL
GERIATRIX
Hey Guys,
When i press in the clutch during starting, i hear what sounds like lifter noise. Also while driving i hear the noise at around 3000rpm, usually when i shift. While i am driving, i hear the noise if i let off the gas and it goes away when i apply the gas. I did a complete oil change including oil filter. Oh, i switched to 100% synthetic with this new oil change. Also b4 i drained the old oil i ran it for awhile with Seafoam. Will this noise go away after some running time or do i need to have the valves replaced? Or is it possible the clutch is at fault?
Feb 16, 2009 at 7:58 AM
ROBIROB
it could be your throwout bearing
Dec 14, 2010 at 9:18 PM
ROBIROB
Dec 14, 2010 at 9:19 PM
  • 110,246 POSTS
Are you sure the noise is coming from the engine?
Dec 17, 2010 at 11:17 AM
