2003 Mazda Protege how much fluid is need
2003 MAZDA PROTEGE
82,375 MILES • 4 CYL • FWD • AUTOMATIC
POLLITO85
My transmission was dragging I never check the oil for the transmission sadly an after seeing it was dragging I checked it an it was showed hardly any fluid so I put three qts but I'm still seeing it's a lil low even though the cars running fine now an I'm still unsure of how much fluid it takes an I'm also seeing no leek so wondering where did it all go too if the vacuum has anything to do w it
Jun 9, 2010 at 12:17 PM
Keep the engine running as you check the fluid keep feeding it till it comes up to full mark then stop.
If you have a vacuum modulator could go thru there and suck into the engine if the diaphragm is ruptured
Jun 9, 2010 at 12:26 PM
