2002 Mazda Protege poss. idle air control valve bad???
115,000 MILES • 4 CYL • FWD • AUTOMATIC
DEREKLEVI
The car drives fine on free way or the regular road, the problem is when i come to a stop the idle seems like it wants to die, but never does. there is no engine light on. (i also scanned it). i checked the fuel presure regulator, seemed to be good. i sprayed carb cleaner around the hoeses, while running no leaks. there are new plugs.
May 9, 2010 at 5:07 AM
  • 75,988 POSTS
Try cleaning out the idle air control valve and the EGR and PCV valves and test the throttle position sensor and airflow meter.
May 9, 2010 at 4:19 PM
