2002 Mazda Protege overheating w/ battery light on
84,000 MILES • 4 CYL • 2WD • AUTOMATIC
CHANDRAALTO
I was driving and my battery light came on. I was close to home so I waited to get home to stop. When I parked a large amount of steam rose from the hood. I popped the hood and my antifreeze overflow was rapidly boiling. I believe I replaced the thermostat about 18 mos ago. What could be the problem?
Oct 15, 2010 at 6:50 AM
SATURNTECH9
  • 30,869 POSTS
First of all thank you so much for your donation.Let's start with why your battery light is on.That could be the same reason your car is overheating.Check and see if your drive belt is tight.Also do you have a multimeter?
Oct 15, 2010 at 7:17 AM
CHANDRAALTO
yes, I have a mutimeter, what do I need it for?
Oct 15, 2010 at 5:19 PM
SATURNTECH9
  • 30,869 POSTS
You will use the multimeter to do some testing.See if the engine start's if it won't crank have the battery charged and tested.If it does start see what the voltage reading is at idle at the battery.Let me know what you find.
Oct 16, 2010 at 4:02 AM
