2002 Mazda Protege Oil Filter Location
LIHC
I am currently working on my old lady's 2002 Mazda Protege ES. It's got 57,000 miles in it. I have encountered one problem after another with this damn car....
My current issue is the OIL FILTER!! It is inside the motor. There are no instructions what so ever in the owners manual (of course) it just tells you to bring it to the dealer. So they can rape youu on labor costs.
My question is what else do i have to remove besides 8 retaining bolts around the top of the motor?... Do i have to remove the Spark Plugs? Is there a locking mechanism of some sort? it seems as if it should lift clean off but it doesn't. and once it's off is there a gasket that needs to be replaced as well? I can't find a reapir manual on this car anywhere and i have plenty of access to them. The work itself doesn't seem to bad it's just that i don't want to ruin anything on her car.
Thank you for your help!
Dec 17, 2006 at 1:21 PM
BRUCE HUNT
  • 3,754 POSTS
I don't have access to the manual on that car but I suggest that you go to the auto parts store and get a maintenance manual for about $20. Great investment.
Dec 18, 2006 at 1:35 AM
COSMO
  • 347 POSTS
whoa whoa whoa....
2002 Protege 2.0L......the filter is on the back of the motor under the intake......if you look down below the intake near the alternator you will be able to see it.
I think there might have been some sort of mis-communication with the manual or a type-o of some sort.
It is easily accesable.
oh and btw I work for a dealer that "will rape you for labor costs".......so your welcome....I have to make a living too so piss off with comments like that.
Should cost you $40 CND for a basic oil change
Cosmo...Mazda Tech
Dec 19, 2006 at 3:32 AM
Suggested Repair
On the 2002 Protege 2.0L, the oil filter is a conventional filter at the rear of the engine, below the intake near the alternator. It does not require removing the valve cover, spark plugs, or retaining bolts. Access it from above or behind the intake and replace it during a normal oil change. A maintenance manual is a useful reference.
Conversation Summary
The owner believed the 2002 Mazda Protege oil filter was inside the engine and asked whether the valve cover bolts, spark plugs, a lock, or a gasket had to be addressed. One reply suggested buying a maintenance manual. A Mazda technician clarified that the filter is easily accessible at the rear of the 2.0L engine under the intake near the alternator, so the valve cover does not need to be removed.
