2002 Mazda Protege No pressure in cyl no2 oil inside
TWOBROTHERS
Engine Performance problem
2002 Mazda Protege 4 cyl Front Wheel Drive 160000 miles
I have no preassure in cyl no 2 and its full of oil, is it piston rings or valve problems? thanking u in advance Ruben
Jun 10, 2009 at 11:17 AM
  • 31,937 POSTS
Hi there,
This could well be a cracked piston or broken rings, a leak down test will tell you if its rings/piston or valves, but with the oil in the cylinder more than likely rings/piston.
mark (mhpautos)
Jun 10, 2009 at 11:20 AM
