2002 Mazda Protege Dry Oil Filter when changed
109,000 MILES • 4 CYL • FWD • MANUAL
TD54240
I have been changing my own oil for decades. The last two oil changes I have found that the oil filter is dry and the filter appears to be unused. Before going to a mechanic I would like to know what would cause oil to bypass the filter. The car runs fine and there is no oil pressure light. I checked oil levels after putting in a new oil filter and checked again after starting the car. I see no difference (it is a small filter but I expect to see a difference).
Aug 8, 2009 at 4:53 AM
BUDDYCRAIGG
  • 2,262 POSTS
the bypass valve must not be working. maybe the spring broke.
But even then i would expect the filter to have [i:ab1de81b6a]some[/i:ab1de81b6a] oil in it.
Aug 8, 2009 at 10:42 AM
