2002 Mazda Protege Car shutdown
MICHAELBRULEY
  • 2002 MAZDA PROTEGE
  • 4 CYL
  • 4WD
  • 160,000 MILES
Was driving and car shutoff while driving! Tried to start again but car would not turnover ! It cranks like it going to but does not what can this be?
Monday, March 15th, 2010 AT 2:40 PM
Do below to determine whether it's fuel or spark issue.
Cranks but no start condition:
Fuel and Spark:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Monday, March 15th, 2010 AT 10:42 PM
