My Mazda Protege MP3 while driving stalled. The car stalled smoothly as if it were fuel related, but had sufficient fuel (1/2 tank). When I attempted to restart the vehicle, it would crank but not start. First, I checked the fuel pump to verify that it was working and pumping fuel. It checked out and I decided to add more fuel. The car crnked and started and was fine for approximately a week. This time, after driving and stopping at the store, when I tried to restart the vehicle, it would crank, but not start with 1/4 tnk of fuel, but I could not hear the fuel pump wine. Prior to replacing the fuel pump, I verify that it was receivng voltage at the pump, which it was. I replaced the fuel pump and strainer, and the car started, but quickly died, and would not restart. I verified that the new pump was pumping by removing a a fuel line from the fuel pump assembly, and while cranking observed gas pumping from the tank, but still the engine doesn't start. Can you provide me any assisted on the next step to try? I am going to verify that I am getting fire atthe spark plugs, and fuel up to the fuel pressure to the injector rail.
Nov 1, 2009 at 3:18 PM
