2001 Mazda Protege Power Windows
2001 MAZDA PROTEGE
BOJANGLES
Interior problem
2001 Mazda Protege 4 cyl Two Wheel Drive Automatic 100k miles
My 2001 Protege has 100,000 miles but is well maintained and runs great. The other day I encountered what appears to be my first problem. After sitting in my car for a few moments with the 2 front windows down, I went to close them. The driver window went up no problem, but the passenger window refused. Curious, I checked the back two windows and they have no power either. I tried replacing both of the pwr w fuses, but that didn't work. 2 questions: 1) how can I get my window up for the time being? 2) what are some possible problems/solutions?
Thank you very much.
Dec 3, 2008 at 2:08 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello
Thanks for the donation.
Open the door, place one hand on the outside of the glass then take the other hand and place it on the inside of the glass and push it back to the top. Be careful not to apply pressure inward/outward causing the glass to bend and then shatter. If the window is all the way down then the door panel has to be removed.
Test the main switch (driver switch) for power when applying to each window. Also test subswitches (individual switches on other doors) for power as well.
Hope this helps.
Dec 3, 2008 at 5:09 PM
