2001 Mazda Protege Better Type of Struts
2001 MAZDA PROTEGE
135,000 MILES • 4 CYL • 2WD • AUTOMATIC
BROWNKW
What is a good type of struts for my car because whenever I hit any bumps the car sounds like the front end could fall apart? Need a little help? Had everything replaced about a year ago and the suspension sounds worse than when i put it in the shop.
Mar 18, 2009 at 6:55 PM
BLACKOP555
  • 10,386 POSTS
can you describe the sound better? better struts wont necessarly fix it if that isnt the problem with your vehicle.
why you deem the struts bad?
Mar 19, 2009 at 7:58 PM
BROWNKW
I know that a wheel alignment is needed but the front end rattles when ever you drive over a bump.
Mar 20, 2009 at 12:03 AM
BLACKOP555
  • 10,386 POSTS
check the strut, and the strut bushings?
check sway bars and other front end bushigns to make sure its tight.
Mar 20, 2009 at 7:19 PM
BROWNKW
Thanks I'll check that out his week.
Mar 22, 2009 at 8:14 PM
BLACKOP555
  • 10,386 POSTS
let me know what you find!
Mar 24, 2009 at 8:31 PM
