2000 Mazda Protege overheating
2000 MAZDA PROTEGE
77,000 MILES • 4 CYL • 2WD • AUTOMATIC
PLECHELER
What we believe happened is our vehicle overheated and smoke was coming out under the hood. The dealership said we blew the engine and would need to replace the engine. We found an auto shop who replaced the engine with a used one with 34K miles. About 200 miles later after picking the car up, the car overheated on the freeway and had to be towed back to the shop. The owner said the problem was an alternator and water pump and a missing belt, so we had him fix that. About 150 more miles after that was fixed, again the vehicle overheated on the freeway, and again towed back to the shop. This time he says it's the head gasket, and is saying it'll cost another $600. He says it is not the engine nor anything to do with the replaced engine. My question is could the head gasket have been damaged as a result of a bad engine? Or is it something totally unrelated? If we fix the head gasket, what else could go wrong with the engine and/or cooling system that would not have anything to do with the engine. We feel we are throwing money at this shop dealer, and he isn't really fixing the problem.
Aug 17, 2010 at 2:36 PM
KHLOW2008
  • 41,814 POSTS
Hi plecheler,
I would say the problem is from the engine or workmanship and the shop should be responsible for all the repairs.
Did you buy the engine or was it from the shop that replaced it?
Aug 23, 2010 at 6:00 AM
PLECHELER
The shop that replaced the engine purchased the engine and put it in. We purchased an extended warranty on the engine. The shop is now telling us that the warranty is "null and void" since the heat center tab blew off.
Sep 4, 2010 at 3:41 AM
KHLOW2008
  • 41,814 POSTS
What is the heat center tab that you are referring to?
I do not know if it is in direct relations to the repair job carried out so am ot able to comment.
The warranty for the engine does seem to be void as it is not the engine that is at fault but you can still make argue with the shop for not checking out the components concerned, which could be the cause of the original engine failure.
Sep 4, 2010 at 4:48 AM
