1999 Mazda Protege engine overheating
125,000 MILES • 4 CYL • 2WD • AUTOMATIC
JASON HUBERT
overheating.. changed water pump, thermostat, radiator, upper and lower hose, fan switch/temp sensor, flushed system completly and the overflow tank still gets full and leaks on the ground and when enough coolant leaks out then it overheats.
Sep 11, 2010 at 6:14 PM
  • 75,988 POSTS
Try bleeding the coolant system and see what happens
Sep 11, 2010 at 9:47 PM
JASON HUBERT
i did try bleeding the coolant and still the car overheats. i cant understand what else could be causing this car to overheat. i even put a 165 degree thermostat in and no luck. the fans are working???? i am stumped. i have had two other mechanics look at it and they have no clue.
Sep 12, 2010 at 3:14 PM
  • 75,988 POSTS
It's time to get it block and pressure tested
Sep 12, 2010 at 3:23 PM
