Engine Mechanical problem
2000 Mazda Protege 4 cyl Two Wheel Drive Automatic
Hi there ... I need to replace the header pipe of my car, the piece just before the cat. I guess I'll have to replace the gasket as well
The question is, do I need to replace the O2 sensor inserted in the header pipe as well?
The mechanic said I better change the O2 sensor, but I don't see the reason as the pipe broke due to rust when joined the back part of the pipe
Why would I need to replace the sensor that is quite expensive
I'd appreciate any advice
Thanks
Thanks
Jun 13, 2009 at 12:26 PM
