2000 Mazda Protege Hard to start
180,000 MILES • 4 CYL • FWD • AUTOMATIC
MVAMOBILE.COM
  • 9 POSTS
Hello, this car has a hard time starting. Sometimes it will not start and I have to press the gas pedal to the floor for about 2 seconds then let off and it starts. Sometimes it starts while the gas pedal is pressed. Sometimes it starts fine. Could this be a fuel system or intake problem?
Oct 17, 2008 at 3:37 PM
BLACKOP555
  • 10,386 POSTS
does it do it in pattern? matter with the weather?
try giving it a shot of starting fluid down the throttle body each time you start it.
if it fires up each time then you could suspect a fuel trim sensor/issue with fuel system.
if not it may be spark, but more then likely it is fuel. get back to me.
Oct 18, 2008 at 1:34 AM
