2000 Mazda Protege air flow sensor
2000 MAZDA PROTEGE
ALEX22
2000 Mazda Protege
Mazda protege 2000
I replaced the engine with a used one.
I have the check engine light on and the code pointed to air flow sensor. The engine is stalling and it hardly starts when is cold. Do you think the sensor is causing those ? Thanks a lot !
May 21, 2008 at 12:35 PM
LEGITIMATE007
  • 5,121 POSTS
yes, also check your idle air control valve
May 21, 2008 at 3:14 PM
ALEX22
[quote:f86d808864="legitimate007"]yes, also check your idle air control valve[/quote:f86d808864]
Thanks a lot
I replaced the sensor - it is OK now
Jul 25, 2008 at 4:08 PM
