I cannot remove the driveaxles from the thansaxle, I have removed the control arm and tie rod but cannot budge the CV Joint Housing. What is the proceeedure here? I am not removing the drive axles from the hub as I am 'only' trying to change the clutch. How about the right side, it has an axle piece then the CV Joint housing. How does this come apart? Thank you.
Jun 14, 2009 at 6:54 AM
