1999 Mazda Protege hypothetical question
1999 MAZDA PROTEGE
DEB_M
  • 5 POSTS
Engine Mechanical problem
1999 Mazda Protege Engine Size unknown Front Wheel Drive Automatic 127000 miles
My car broke down while driving it. The oil light had been going on and off for some time (even though I had an oil change three weeks prior). If you were the mechanic working on this car and discovered that cruddy had prevented good oil from reaching the camshaft and cylinder head (journals were also damaged) as a result the two pieces fused together also causing damage to the timing belt.
What would you have done to repair the problem and why?
If there was cruddy oil in that part of the engine, would it not be reasonable to assume other parts also had cruddy oil?
How difficult would it be to check?
Thanks for your help.
Mar 13, 2008 at 10:23 AM
MASTERTECHTIM
  • 4,750 POSTS
engine is most likely no good. your not trying to fix the head and see if it is ok. are you. its cheaper to install a used engine, in my opinion.
Mar 13, 2008 at 10:38 AM
DEB_M
  • 5 POSTS
That's precisely what my mechanic did :'(
Should my mechanic have known that it was reasonable to assume that there was cruddy oil elsewhere in the engine?
Would future problems related to the crud still left in the engine be likely? If so how likely?
Thanks again!
Mar 21, 2008 at 5:01 AM
