1999 Mazda Protege driving in snow
98,000 MILES • 4 CYL • FWD • AUTOMATIC
MAZDERO99
I recently bought a used car. The tires are all season radials in decent shape (not worn). The car (a 1999 Mazda Protege ES) has a lot of trouble moving in the snow. This is particularly bad when trying to back up. I thought it perhos the was the type of snow we recentky had that made this bad (very wet and heavy snow) but other cars (many not all wheel drive or SUVs) handled the snow fine. It does not appear to be a steering issue because I was simpy trying to move backward and forward. The car just would not budge even in the middle of a sttreet thhat was not all that deep with snow. When in normal conditions it runs fine My friend's car runs fine in snow and when I checked my tread against his they were about the same. What might be the problem? Thanks much
Feb 10, 2010 at 7:42 AM
PROTEGENICK
I don't know if this has been checked but I experienced this very problem and found that my emergency brake cable was not releasing properly. In good weather the engine could over come the drag but as the emergency brakes are in the rear wheels and the front wheels are driving the car they fight in the snow usually with the emergency brakes winning the tug of war.
Good luck.
[quote:6dd2e81b8c="mazdero99"]Tires and Wheels problem
1999 Mazda Protege 4 cyl Front Wheel Drive Automatic 98000 miles
I recently bought a used car. The tires are all season radials in decent shape (not worn). The car (a 1999 Mazda Protege ES) has a lot of trouble moving in the snow. This is particularly bad when trying to back up. I thought it perhos the was the type of snow we recentky had that made this bad (very wet and heavy snow) but other cars (many not all wheel drive or SUVs) handled the snow fine. It does not appear to be a steering issue because I was simpy trying to move backward and forward. The car just would not budge even in the middle of a sttreet thhat was not all that deep with snow. When in normal conditions it runs fine My friend's car runs fine in snow and when I checked my tread against his they were about the same. What might be the problem? Thanks much[/quote:6dd2e81b8c]
Feb 11, 2010 at 3:37 AM
