1999 Mazda Protege car stops running with no code
MURRAY45
Engine Performance problem
1999 Mazda Protege 4 cyl Front Wheel Drive Automatic
you are driving and sputer and stop wait about 45 min. and it will start. with no codes.
Jan 9, 2010 at 2:54 AM
KHLOW2008
  • 41,812 POSTS
Hi murray45,
Thank you for the donation.
When the problem occurred, you would need to test/check to see what is mising.
There are various possible causes.
1. Power supply. It could be a faulty ignition switch or loose connections somewhere. It intermittenly fails after heating up and losing continuity. Cooling down allows the contacts to work again.
2. Faulty ignition coil. Heating up causes it to fail.
3. Faulty fuel pump or its circuit.
https://www.2carpros.com/kpages/first_things.htm
The above link shows how to go about checking for whatever that is missing.
Aug 4, 2020 at 5:18 AM
