1998 Mazda Protege water pump replacement
13,580 MILES • 4 CYL • FWD • AUTOMATIC
AUNTIESMRIA
How often should I replace my water pump, and what could either cause it to deteriorate prematurely or confuse a mechanic into thinking it needs to be replaced when it doesn't? I replaced my timing belt and water pump 2 years ago (4/06) and now my (new) mechanic tell me it needs replacing again. I brought it in last week because the engine was overheating. They replaced a temperature gauge and gasket but now say the water pump also needs replacement. I was ciofused, so I brought it back to my original mechanic who said there was no problem with the water pump that he could see, but that my oil pressure switch was broken. I have not put an excessive amount of mileage on my car in the past two years (approx. 20,000 miles), or driven it in extreme conditions. I really don't want to change the pump - and it goes without saying the timing belt too - after only two years, given the labor costs associated with this service. What is going on here? What questions should I be asking?
Thanks.
Jun 23, 2008 at 5:35 AM
KHLOW2008
  • 41,812 POSTS
Hi auntiesmria,
When the engine overheated, were the cooling fans working?
Was there any shortage of coolant in the system?
Was the thermostat tested?
Was any leaks found?
Overheating occurred under what conditions? City driving or high way speed driving?
Jun 29, 2008 at 12:21 AM
