1998 Mazda Protege po304 code engine light on
101,000 MILES • 4 CYL • FWD • AUTOMATIC
DMURPHY08
Replaced plugs and wires. light still on. car almost stalls when stopped. light flashes on and off then goes solid for a time. recently had oil changed small valve cover gasket leak. car was running rough before oil change. After oil change engine light came on. Any ideas on what to try next?
Mar 26, 2009 at 4:04 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Try cleaning the EGR valve and passages to see if it helps the misfire. Post results and I will follow up.
Thanks for using 2CarPros.com!
Mar 26, 2009 at 4:20 PM
