1998 Mazda Protege draning battery
118,000 MILES • 4 CYL • FWD • AUTOMATIC
ADMIRAL8411
I've replaced and tested a new alternater put in a new battery and replaced the postive and negative wires replaced the spark plugs and wires and a new distribulater and yet the car can only last a few rides before it dies out im at a loss and can't think of any else
Jul 21, 2009 at 3:24 AM
BUDDYCRAIGG
  • 2,262 POSTS
you will need a volt meter.
With everything hooked up like normal.
And the battery fully charged.
The battery should have 12.6 volts with the engine off.
now start the car, it should be above 13.
If it is not, then the car is not charging.
Jul 21, 2009 at 4:44 AM
