1997 Mazda Protege What is the Drive cycle for this Mazda?
227,000 MILES • 4 CYL • 2WD • MANUAL
RAELINJACK
I just replaced the PCM and O2 sensor on my 1997 Mazda Protege. I cleared the computer, still came up with the P1195 error code, went to get the emmissions tested anyway and the system wasn't ready. I need to take it through it's drive cycle. What is the drive cycle for this car?
Thank you so much!
Jan 20, 2009 at 6:59 AM
DAVE H
  • 13,383 POSTS
Hello ..thanks for the donation ... much appreciated Hope this helps Drive Cycle-Mode 1 Start engine and warm to normal operating temperature. Ensure all electrical and A/C loads are off. Ensure ignition timing and idle speed are within specification. Adjust as necessary. See BASIC TESTING - 1.8L article. Ensure no jumper wires are connected to DLC. Increase engine RPM to specified speed. See Fig. 2 . Operate engine at specified RPM for minimum of 15 seconds. Idle engine for more than 20 seconds with cooling fan disabled. Fig. 2: Drive Cycle-Mode 1 Engine Speed Table
https://images.2carpros.com/forum/automotive_pictures/266999_1_8.jpg
Drive Cycle-Mode 2 Start engine and warm to normal operating temperature. Ensure all electrical and A/C loads are off. Drive vehicle at specified speed for one minute. See Fig. 3 . Fig. 3: Drive Cycle-Mode 2 Vehicle Speed Table Courtesy of MAZDA MOTORS CORP.
https://images.2carpros.com/forum/automotive_pictures/266999_2_6.jpg
Drive Cycle-Mode 3 Start engine and warm to normal operating temperature. Ensure all electrical and A/C loads are off. Idle engine for additional 5 minutes. Drive vehicle at specified speed (V1) for one minute. Lower vehicle speed to specified speed (V2) for 3 minutes. See Fig. 4 . Fig. 4: Drive Cycle-Mode 3 Vehicle Speed Table Courtesy of MAZDA MOTORS CORP.
https://images.2carpros.com/forum/automotive_pictures/266999_3_8.jpg
Drive Cycle-Mode 4 Ensure following conditions are met: Engine coolant temperature is 32-95 °F (0-35 °C). Intake air temperature is 50-140 °F (10-60 °C). Barometric pressure is 72 kPa. Fuel gauge needle points within 15-85 percent. Start and operate engine at 3500 RPM for 200 seconds. Within next 40 seconds, accelerate vehicle to 40-60 MPH (65-96 km/H). Maintain vehicle speed for 6 minutes.
Jan 20, 2009 at 8:00 AM
