if that works does that mean the starter siloniod needs to be replaced because with my starter it is attached right to the starter
Sep 26, 2010 at 11:46 PM
BLUELIGHTNIN6
✓ASE Certified Mechanic
no that means most likely the ignition switch is failing
Sep 27, 2010 at 4:49 PM
DIGIT1989
MEMBER
how much does that usually cost?
Sep 27, 2010 at 4:50 PM
BLUELIGHTNIN6
only takes 30 mins or so to replace it on your vehicle, labor fees should be around $40 or so..
Sep 27, 2010 at 4:55 PM
DIGIT1989
MEMBER
how much is the part?
Sep 27, 2010 at 4:56 PM
BLUELIGHTNIN6
looks like autozone has it new for around $110 or you could get used from local salvage yard for probably half the price..
Sep 27, 2010 at 4:58 PM
